您好,请问下在服务器编译时遇到这个问题应该怎么解决?
PKG common (opt)
EXE common_test.exe
DEP tm_usage.d
DEP cmd.d
DEP sys_cmd.d
DEP get_opt.d
DEP common_test.d
CXX get_opt.cpp
CXX sys_cmd.cpp
CXX cmd.cpp
CXX tm_usage.cpp
AR libcommon.a
INS libcommon.a
INS sys_cmd.h
INS cmd.h
INS tm_usage.h
INS vt100.h
INS ascii.h
INS get_opt.h
CXX common_test.cpp
LD common_test
collect2: fatal error: cannot find 'ld'
compilation terminated.
make[2]: *** [lib/opt/common_test.exe:4: bin/opt/common_test] Error 1
make[1]: *** [../../rule.mk:91: install] Error 2
make: *** [Makefile:64: install_common] Error 2
which ld
/usr/bin/which: no ld in (/home/eda230122/.local/bin:/home/eda230122/bin:/usr/local/bin:/usr/bin:/usr/local/sbin:/usr/sbin)
